KPN Box 12 lost connection with my NGINX proxy manager
  • July 13, 2022
  • 122 keer bekeken
AndreScala
Deelnemer
Hi everyone,
I recently changed to KPN and for some reason I’ve lost connection with my NGINX proxy manager, is the router shutting down my 443 and 80 ports?
Just for context, the router is connected directly to my UDM Pro (so, is doing nothing, just send the signal) but since I’ve changed the internet provider I’ve lost that config.
And I’m not getting the IP that my UDM Pro is using!
Any ideias?
Thanks, mvg Scala
Beste antwoord door Anonymous
Hello @AndreScala
Did you put the UDM in DMZ again in the Box 12?
Also you should now have a completely different external ip-adres, are you using that for external access or do you still try to connect to the old (and now wrong) ip-adres?
@AndreScala You better call with customerservice at 0800-0402.
  • July 14, 2022
Hello @AndreScala
AndreScala
Deelnemer
  • July 14, 2022
Hello @AndreScala
Hi @GeSp , somehow I found my other post searching for answers and yes, just activated DMZ and done. Is to expensive to change to a fritzbox. Thanks
  • July 14, 2022
Hi @AndreScala
A UDM Pro is fine, I still use a USG-3P which is just enough to handle a 100/100mbit WAN connection with IPS enabled.
