Recommendations SFP+ module and Unifi 'UDMPro' with fiber
  • March 17, 2024
  • 1056 keer bekeken
Hello KPN friend,
I just got a happy letter for an appointment to check how KPN Network will provide fiber optics.
I currently have a UDM Pro device, and I want to use a direct attachment instead of a KPN setup to get the complete fiber experience instead of ethernet + extra device in the last few meters.
I have checked the forum here, and I found plenty of information like “but not all”:
Yet I have some questions that are yet to be understood, and your help would be much appreciated 🙌
  • Do you have any recommendation for an SFP+ module that would work with the current 4Gbps and ideally be future-proof to 10Gbps? SFP+ modules usually don’t have the SC connector that KPN provides.
  • Would it be possible for the fiber cable to reach the living room “where the rack is”? Would that be an extra cost, or should I get external cabling help?
Thanks in advance
Beste antwoord door TDN
Forum|alt.badge.img+12
  • March 18, 2024
  • March 23, 2024
Thanks @TDN for your reply, I went with the fs + mod, direction.
Do you believe that this mod can be executed on the UDM device via ssh?
  • March 23, 2024
@shyraza If you are not sure to run the mod safetely by yourselfs, you can buy a ready to use fs-module from here (already patched for KPN network).
https://www.schenkict.nl/3-sfp-modules
