Tunnelblick VPN works anywhere but at home
  • May 15, 2025
  • 15 reacties
  • 107 keer bekeken
Hi,
I also have issues with using VPN. It has started happening to me since 4 months ago.
I use VPN for my work to be able to use the server for coding or be able to access research papers that are provided by my institute. We use Tunnelblick
Here is a snippet of the log:
2025-05-15 13:08:35.570638 MANAGEMENT: >STATE:1747307315,WAIT,,,,,,
2025-05-15 13:09:36.013438 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2025-05-15 13:09:36.013587 TLS Error: TLS handshake failed
2025-05-15 13:09:36.014119 SIGUSR1[soft,tls-error] received, process restarting
2025-05-15 13:09:36.014393 MANAGEMENT: >STATE:1747307376,RECONNECTING,tls-error,,,,,
2025-05-15 13:09:36.016960 *Tunnelblick: Delaying HOLD release for 2.000 seconds
2025-05-15 13:09:38.019977 MANAGEMENT: CMD 'hold release'
2025-05-15 13:09:38.020132 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2025-05-15 13:09:38.020616 TCP/UDP: Preserving recently used remote address: [AF_INET]192.16.191.40:1194
2025-05-15 13:09:38.020809 Socket Buffers: R=[786896->786896] S=[9216->9216]
2025-05-15 13:09:38.020845 UDPv4 link local: (not bound)
2025-05-15 13:09:38.020877 UDPv4 link remote: [AF_INET]192.16.191.40:1194
2025-05-15 13:09:38.020972 MANAGEMENT: >STATE:1747307378,WAIT,,,,,,
2025-05-15 13:10:38.902196 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2025-05-15 13:10:38.903094 TLS Error: TLS handshake failed
2025-05-15 13:10:38.903312 SIGUSR1[soft,tls-error] received, process restarting
2025-05-15 13:10:38.903331 MANAGEMENT: >STATE:1747307438,RECONNECTING,tls-error,,,,,
2025-05-15 13:10:38.903958 *Tunnelblick: Delaying HOLD release for 4.000 seconds
2025-05-15 13:10:43.894213 MANAGEMENT: CMD 'hold release'
2025-05-15 13:10:43.894350 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2025-05-15 13:10:43.894605 TCP/UDP: Preserving recently used remote address: [AF_INET]192.16.191.40:1194
2025-05-15 13:10:43.894719 Socket Buffers: R=[786896->786896] S=[9216->9216]
2025-05-15 13:10:43.894740 UDPv4 link local: (not bound)
2025-05-15 13:10:43.894755 UDPv4 link remote: [AF_INET]192.16.191.40:1194
2025-05-15 13:10:43.894799 MANAGEMENT: >STATE:1747307443,WAIT,,,,,,
Any idea on how to proceed to fix the issue. I have tried with IT people from the department but VPN works well anywhere else except when I am at home.
Thank you in advace,
Bests,
Manel
Admin: eigen topic voor vraag gemaakt [origineel topic]
15 reacties
  • May 15, 2025
Hello ​@MSlokom
Did your KPN modem/router receive an update to the new KPN firmware?
If so, it could be that the new firewall blocking a needed port for Tunnelblick.
If you set it to Standaard (in the red part) then it should not be blocking anything, you can change it in the KPN modem/router:
Hoe pas ik de instellingen voor de uitgaande firewall aan?
  1. Open een browser en ga naar 192.168.2.254 of mijnmodem.kpn
  2. Vul je wachtwoord in en klik op Inloggen.
  3. Klik links op Beveiliging
  4. Je komt op deze pagina:
In het blauwe blok kun je instellen of het modem reageert op pingverzoeken. Het gaat hier om verzoeken die vanaf het internet komen. Je kunt een ping zelf gebruiken om van buitenshuis te kunnen controleren of je Box 12 nog actief is. Zet je dit schuifje uit, dan kan dat niet meer.
In het rode blok stel je het beveiligingsniveau in. Er zijn vier opties die hieronder worden uitgelegd. Als je het niveau wijzigt krijg je een pop-up om de wijziging te bevestigen:
See also:
Hi ​@MSlokom, welcome to the community. Have you tried the suggestion GeSp provided? Did that help in your situation?
  • May 17, 2025
Hi ​@Jasper van KPN and ​@GeSp
Thank you for your help. I have made the change but the VPN did not wor.
log:
2025-05-17 21:39:24.653017 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2025-05-17 21:39:24.664960 TCP/UDP: Preserving recently used remote address: [AF_INET]192.16.191.40:1194
2025-05-17 21:39:24.665138 Socket Buffers: R=[786896->786896] S=[9216->9216]
2025-05-17 21:39:24.665156 UDPv4 link local: (not bound)
2025-05-17 21:39:24.665169 UDPv4 link remote: [AF_INET]192.16.191.40:1194
2025-05-17 21:39:24.665204 MANAGEMENT: >STATE:1747510764,WAIT,,,,,,
Bests,
Manel
Forum|alt.badge.img+12
  • May 17, 2025
@MSlokom Try to turn off IPv6 in the KPN modem
Forum|alt.badge.img+7
  • May 18, 2025
This is very strange, the messages are from OpenVPN trying to make a TLS connection to a IPv4 server which is specified by address on UDP port 1194. Switching off IPv6 will not help. On KPN box 10 this works without any problem with outgoing firewall on standard or customized/allow all, the medium setting works too.
Did the connection failure coincide with the upgrade of the router firmware or some other change ?
  • May 18, 2025
If I am not wrong, the IPv6 is already off.
Still, the VPN is not working.
@hmmsjan_2 How can I know which KPN box I have? I remember that VPN was working fine, until one day it does not work anymore. I did not change anything. I suspect that something happened from KPN side (e.g., updates!).
  • May 18, 2025
In the admin portal status page.
KPN recently blocked PPTP protocol, but Tunnelblick uses OpenVPN en would never be blocked, neither by modem firewall nor KPN side.
But which subnet does CWI use? If it uses the subnet 192.168.2.xxx, VPN does not work with default subnet of KPN modem.
  • May 19, 2025
In principle you should have got a SMS just before the router has been upgraded.
The box type can be found on it’s admin page at http://192.168.2.254. You even do not have to login with the new firmware version to see the box type and firmware versions.
The firmware upgrade introduces a firewall for outgoing packets, before all outgoing traffic was allowed. In the “medium” setting, some protocols sending username and passwords in plain text over the wire are blocked. OpenVPN on port 1194 should not be blocked. Firewall “standard” in this context means “just as it was before”, so this setting should block nothing.
Since the aim of the new firmware is having the same software on all different hardware, a working connection on box 10 should be a working connection on all other boxes.
In the “port forwarding” section of the router, there is no need for OpenVPN/1194UDP entries, may be someone suggested this for troubleshooting. This is only needed if you run an own OpenVPN server. In theory (and praxis) they should not interfere, unless (may be) openvpn is configured to use port 1194 as source port. If you have such a port forwarding entry, try to switch it off, but I do not expect improvement.
Other changes in KPN environment are transition from DSL to fiber, where the IP address changes. Since you mention “from anywhere but home”, I assume your institute does not use whitelists to restrict access, but let check for blacklisting.
  • May 30, 2025
Sorry for going silent for a while! I was not home in the last period.
If I understand ​@hmmsjan_2 correctly, I have to check the status of “Forwarding port” and it has to be off. Actually it is the case, it is by default off.
  • May 30, 2025
Port forwarding is not needed for outgoing traffic, but you didn't answer my question, which subnet does CWI use? If it overlaps with KPN subnet (default 192.168.2.0/24), a VPN connection won't work
  • May 30, 2025
As the log indicates, the connection does not reach the stage that a VPN interface is created with a possibly overlapping IP address.
If you have easy contact with your IT, you can ask them to run “tcpdump” on the routers WAN side, filtered with your external IP address, at the same time that you setup a connection from home to see whether something comes in. If not, I do not understand because the outgoing firewall should pass the packets.
But this will probably be only possible with a very small IT organization not busy with processing a stack  of tickets.
  • May 30, 2025
Hi ​@TDN thanks for your help!
Any idea where I can find CWI’s subnet.
Is it in this log <marked in red>:
2025-05-30 11:46:33.178680 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2025-05-30 11:46:33.184332 TCP/UDP: Preserving recently used remote address: [AF_INET]192.16.191.40:1194
2025-05-30 11:46:33.184488 Socket Buffers: R=[786896->786896] S=[9216->9216]
2025-05-30 11:46:33.184508 UDPv4 link local: (not bound)
2025-05-30 11:46:33.184523 UDPv4 link remote: [AF_INET]192.16.191.40:1194
2025-05-30 11:46:33.184556 MANAGEMENT: >STATE:1748598393,WAIT,,,,,,
2025-05-30 11:47:33.855200 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2025-05-30 11:47:33.855353 TLS Error: TLS handshake failed
  • May 30, 2025
@MSlokom 192.16.191.0/24 is the public IP range of CWI. You can see the private IP range of CWI when you're at work and go to network setting of the network card. You can ask the CWI administrator too.
CWI (the national research institute for mathematics and computer science of Netherlands) is not small and has enough know-hows in ICT
  • May 30, 2025
When using mobile data, I manage to use VPN. Here is the log:
2025-05-30 12:08:09.668828 Initialization Sequence Completed
2025-05-30 12:08:09.668850 MANAGEMENT: >STATE:1748599689,CONNECTED,SUCCESS,192.168.38.67,192.16.191.40,1194,,
2025-05-30 12:08:09.668856 Data Channel: cipher 'AES-128-GCM', peer-id: 13
2025-05-30 12:08:09.668860 Timers: ping 10, ping-restart 60
2025-05-30 12:08:09.668863 Protocol options: explicit-exit-notify 1
2025-05-30 12:08:10.914678 *Tunnelblick: DNS address 192.16.184.42 is being routed through the VPN
  • May 30, 2025
Right! I will check this point with the IT person on Monday.
Previously, he checked with me the issue and did not know what is wrong :) .
