Nope. Na een half uur de kabel eruit, lampje rood. Uit en aan en het begint met een constant paars lampje, dan langzaam groen knipperen, dan snel, dan constant rood.
Tijdens de derde poging zie ik twee nieuwe vermeldingen onder de aangesloten bekabelde apparaten:
- WiFiExtender-xxxxxx\040Master\041 (letters en nummers vervangen met x)
- wifi bridge
Maar zodra de kabel eruit gaat, opnieuw lampje rood.
LOG:
12.01.2024 19:27:16 2 4 9] Start logging.
12.01.2024 19:27:44 2 4 1] HTTP-start ...
12.01.2024 19:27:44 2 4 1] Current firmware version is 1.00.21 and boot flag is 0.
12.01.2024 19:27:45 54 4 1] IFI2.4G]:BSS WiFi driver reboots
12.01.2024 19:27:45 54 4 1] IFI5G]:BSS WiFi driver reboots
12.01.2024 19:27:56 64 4 0] Free Memory 71160K.
12.01.2024 19:27:58 82 4 2] OWL-start
12.01.2024 19:27:59 94 4 1] IFI2.4G]:BSS WiFi driver reboots
12.01.2024 19:27:59 94 4 1] IFI5G]:BSS WiFi driver reboots
12.01.2024 19:28:00 04 4 1] IFI5G]:BSS WiFi driver reboots
12.01.2024 19:28:06 62 4 2] OWL-Backhaul Monitor Start.
12.01.2024 19:28:56 62 2 6] Time Server connected but Server responded with Error(1).
12.01.2024 19:29:28 84 4 0] Ethernet Port 0 Link Up.
12.01.2024 19:29:32 22 4 2] OWL-Backhaul Ethernet being used for uplink mode.
12.01.2024 19:29:39 92 4 4] DHCPC-Obtain new IP 192.168.2.151 and netmask 255.255.255.0
12.01.2024 19:29:39 92 4 1] HTTP-start ...
12.01.2024 19:29:39 92 4 1] Current firmware version is 1.00.21 and boot flag is 0.
12.01.2024 19:30:21 22 4 6] NTP-Time Server successfully connected and time synchronisation achieved.
12.01.2024 19:30:32 34 4 1] IF 2.4G]:BSS WiFi driver reboots
12.01.2024 19:30:32 34 4 1] IF 5G]:BSS WiFi driver reboots
12.01.2024 19:30:33 34 4 1] IF 5G]:BSS WiFi driver reboots
12.01.2024 19:34:14 13 4 1] 1xmppclt.c]: XMPP: Connected, bound jid JB13005B6944FE3BWE410443B99@zwolle3.cust.kpn.net/hdm
12.01.2024 19:34:27 23 4 1] 1xmppclt.c]: XMPP: Get connection request
12.01.2024 19:50:18 14 4 1] IF 2.4G]:BSS WiFi driver reboots
12.01.2024 19:50:18 14 4 1] IF 5G]:BSS WiFi driver reboots
12.01.2024 19:50:18 14 4 0] Ethernet Port 0 Link Down.
12.01.2024 19:50:20 22 4 2] OWL-RE work fine, but no uplink, turn off downlink backhaul Wi-Fi SSID.
12.01.2024 19:50:35 32 4 2] OWL-RE work fine, but no uplink, turn off user Wi-Fi SSID.
12.01.2024 19:51:15 14 4 0] Ethernet Port 0 Link Up.
12.01.2024 19:51:23 22 4 2] OWL-Backhaul Ethernet being used for downlink mode.
12.01.2024 19:51:25 22 4 2] OWL-Backhaul Ethernet being used for uplink mode.
12.01.2024 19:51:32 32 4 4] DHCPC-Obtain new IP 192.168.2.151 and netmask 255.255.255.0
12.01.2024 19:51:32 32 4 1] HTTP-start ...
12.01.2024 19:51:32 32 4 6] NTP-Time Server successfully connected and time synchronisation achieved.
12.01.2024 19:51:32 32 4 1] Current firmware version is 1.00.21 and boot flag is 0.
12.01.2024 19:54:20 :2 4 1] HTTP-User login from 192.168.2.9.
12.01.2024 19:56:28 :2 4 1] HTTP-Key parameters are modified from 192.168.2.9 on Change default password
12.01.2024 19:56:34 :2 4 2] OWL-Sync passwd done.
12.01.2024 19:58:38 :2 4 1] HTTP-Find new Firmware 1 from auto upgrade server.
Een schone installatie geprobeerd: reset van de Superwifi v1, reset van de Box 12, Superwifi verbonden aan de Box met de Ethernet kabel, 15 minuten laten gaan. Lampje van paars, naar knipperend groen (eerst langzaam dan snel) toen knipperend paars en knipperend blauw naar uiteindelijk constant groen.
Kabel eruit, lampje rood.
@Crike , je plaatst hem draadloos als ik het goed begrijp? Geef de wifi punt even de tijd nadat je hebt losgekoppeld. Wacht gewoon 5 a 10 min. Dit is normaal gedrag. Uiteindelijk zal de groen stabiel blijven branden of oranje, bij oranje wil dat zeggen dat je hem dichter bij het modem of andere wifi punt moet proberen te zetten.
@Steve Mnt Het is normaal dat het lampje (eerst) rood wordt wanner je de Ethernetkabel eruit trekt, na de setup?
LATER
Zelfs na een half uur is het helaas niets meer dan een nachtlampje met rood licht. Niets.
Hallo @Crike ,
Heeft jouw Box 12 de nieuwste software?
Dat werkt namelijk niet goed met SuperWifi 1. Daarom wordt die software-update nu niet massaal uitgerold.
Jouw Box 12 moet dan eerst weer terug naar de oude softwareversie.
Lees er hier meer over:
Hallo @Crike ,
Bedankt voor de opheldering.
Ja, ik heb kennelijk V12.C.23.04.39. Hoe kan ik die terug draaien? Volgens het artikel dat je heb gelinkt is dat niet mogelijk.
Firmware-updates zijn niet terug te draaien naar een vorige versie @Crike
Als de firmware het probleem veroorzaakt, zijn er dan nog oplossingen of is de Superwifi v1 min of meer gebrickt als los wifi punt?
Je kan de superwifi 1 punten nog wel gebruiken maar dan moet er 1 bekabeld aan de box 12 modem aangesloten worden en dient Wifi op de box 12 modem uit worden gezet.
Of de SuperWiFi 1 punten te vervangen met Superwifi2 punten met de juiste Firmware erop zodat de box 12 modem ook mee kan draaien in de Wifi mesh.
Maar als losse wifi punt is het dus niet meer te gebruiken? Ik neem aan dat KPN "de meldingen onderzoekt" en "het team werkt aan een snelle oplossing" sinds de lancering van de nieuwe firmware, een halfjaar geleden? Geen hotfixes of workarounds?
Er zal vast en oplossing komen, wanneer is nog niet bekend. Kennelijk is het niet zo eenvoudig op te lossen, want dan was het al lang gefixt.
Aii, @Crike! Als je nu de nieuwe firmware hebt, werkt de SuperWifi 1 inderdaad niet draadloos. Had je die SuperWifi al aangesloten? Of heb je deze nu net gekocht? Je kunt deze inderdaad wel bekabeld aansluiten.
