Wifi Extender is glowing purple when I disconnect it
  • feb 17, 2025 6:30 p.m. UTC
  • 1 reactie
  • 50 keer bekeken
My second WiFi extender was unplugged. Its now glowing purple. I have pressed reset and reconnected it to the modem with the wire and its green. But when I unplug it and move it it glows purple again.
Beste antwoord door PPR058x
​@Cleo1973
When it's purple you have to connect it wired to you're modem for one hour. Then unplug it and it stays green. It has to install the software again
1 reactie
PPR058x
Forum|alt.badge.img+4
  • KPN medewerker
  • feb 17, 2025 6:40 p.m. UTC
​@Cleo1973
