Change of place of residence. Can I move my connection?
  • 5 oktober 2020
  • 10 reacties
  • 651 keer bekeken
Can you bring the Internet with you to your new apartment?
Beste antwoord door Demidoff
Alex_P  and Zeonz
Thank you for answering the topic. According to the link that the moderator gave a link(to inform about the move) wrote there on the 26th, I will choose. I'm waiting now when they make the Internet.
THANKS AGAIN FOR THE ANSWERS !!!!!!
10 reacties
  • 23409 reacties
  • 10 oktober 2020
Hi @Demidoff, welcome on our board.
That depends, what does this site say when entering your new postal code and house number? You will also need to let us know that you’re moving and when you will be moving to your new address.
  • 9 reacties
  • 10 oktober 2020
Moved a week ago, at that address, repairs will be done, I think for a long time. Now address is ********
As I understand it, you can transfer.
  • 23409 reacties
  • 10 oktober 2020
Yes, I can see that it's possible. Did you already let us know?
  • 9 reacties
  • 10 oktober 2020
Yes, I did!
  • 85 reacties
  • 10 oktober 2020
I think what Alex_P here means is, did you already contact KPN (outside of this forum) to let them know that you we're moving and that would like to move you're connection to the new address? And if so, did you get a confirmation through mail that you we’re gonna move and that you're new connection will be transferred to you're new address?
I'm not certain if the moderator's on this forum can input this change for you. Also please remove you're address from the forum post (you can add this into you're profile, those with "Privé” next to them are only visible to the moderator's of this forum). Since this is a public forum anyone on this forum can now see you're address, and I doubt that's what you want.
  • 23409 reacties
  • 10 oktober 2020
Yes. And we can't, but he can do it himself here as mentioned above. :relaxed:
  • 9 reacties
  • 10 oktober 2020
Alex_P  and Zeonz
  • 23409 reacties
  • 10 oktober 2020
Demidoff schreef:
Alex_P  and Zeonz
You're welcome, let me know if I can help with anything in the future.
  • 9 reacties
  • 10 oktober 2020
Alex_P
The only question. If I chose the move date October 26th. Will the installer come to me on the same day?
  • 23409 reacties
  • 11 oktober 2020
Usually yes, otherwise we will let you know. Be sure to check the confirmation after entering the move.
