Need to know which MIMO config KPN Box 12 and 14 supports 3x3? 4x4 ?
  • November 7, 2024
  • 87 keer bekeken
Please letme know what spatial streams/ mimo config does box kpn12 and kpn box 14 supports. Expecting a response.
Thank you
Beste antwoord door VwDt
Box 12
WiFi 2.4GHz 2x2:2
WiFi 5GHz 4x4:4 source
Box 14
WiFi 2.4GHz 3x3
WiFi 5GHz 4x4
source  (the same link as the "Box 14 specifications")
2 reacties
Sanne van KPN
Hi @pioneerkartik! That's a good question.
I haven't been able to find the answer, so I'll link you to the Box 12 specifications and the Box 14 specifications.
Hopefully your answer can be found there!
If the pages are difficult to read in Dutch, know you can translate them through Google Translate.
If you put the weblink in there and translate it, another link will show up in the box with your preferred language. If you click the link there, you'll see the page in your preferred language!
  • November 10, 2024
Box 12
WiFi 2.4GHz 2x2:2
Box 14
WiFi 2.4GHz 3x3
WiFi 5GHz 4x4
