I can't share data with my wife's number
  • January 2, 2023
  • 81 keer bekeken
Hi, I have two numbers registered in my house number. One with unlimited data and the other a simple one. I cannot share my data through the app and apparently it should work automatically.
I saw in another forum topic that other people faced the same and got it fixed with your help. Mind checking my case?
thanks in advance
Hi @rlira, welcome to the forum. To be able to share data between 06-numbers they both need to be registered to the same Hussel registration.
That is the first step, are they registered? You can check this on this page: Bekijk je voordelen.
If they are not yet registered, you can follow the steps there to do that.  What do you see when you take a look there?
  • January 9, 2023
Hi, they were not! Information was not clear to me. Thanks for pointing that out :)
You're welcome, glad I could help! Ig there is anything else we can do for you, don't hesitate to ask us.
