Hi all
Received my kpn 4gbps connection today.
Curiously, when i plug the Nokia box output directly to my unifi cloud gateway ultra, and configure pppoe, I get internet, though only around 1.5 gbps down and up. That is expected though with the ucgu limitations.
However then I plugged in the box14 in between Nokia and ucgu. Used default settings for it and revert off vlan and on dhcpv4/v6on the ucgu and can’t get any internet, ucgu just says I’m not seeing any connection.
What am I doing wrong?
Still have my ziggo connection and modem and when I plug it in (bridge mode), boom the internet is back.
So pretty sure it’s something in my kpn box 14 settings?
ideally want to be using the full bandwidth capability and I think double NAT is prob fine (though bit silly) but for now I cannot even get that option to work.
Thanks!
