KPN Box 12 language setting
  • 11 oktober 2024
  • 341 keer bekeken
Dear Sir,
recently I received KPN box 12 with updated firmware V12.C.24.05.08
when I login to the modem setting, the default language is in Dutch.
is there a way to change language to English? my previous KPN BOX V10 has the option.
The next update should bring some more language options. You can subscribe to our product updates to get a notification when we publish an article about it.
7 reacties
Forum|alt.badge.img+28
  • 37013 reacties
  • 11 oktober 2024
Hallo @Chou ,
Yes, that’s possible.
Heb jij in de browser de optie “Vertalen naar Nederlands” aan staan?
De schermen van de KPN Box 12 zijn standaard in het Engels. Dan staat er Status, Disabled, Security en WPA2 Personal.
  • 11 oktober 2024
I did turn off the auto translate on my browser (Chrome) and also try different browser such as Firefox, Safari, Microsoft edge. none of them works. I did try it with different computer. it's not working, either.
Thomas van KPN
  • 15612 reacties
  • 15 oktober 2024
Hi @Chou, welcome to our community! As Noordzee mentions the box12's webinterface should already be in english. The new software will have an option at the login screen
  • 15 oktober 2024
Hi Thomas,
I am pretty sure the defalut page is in Dutch. and there is no option to switch language.
I found a thread from the KPN box 12, Erik from KPN did mention there is no option switch language to English.
https://community.kpn.com/product-updates/kpn-box-12-update-naar-kpn-software-v12-c-24-05-08-614878/index3.html
Thomas van KPN
  • 15612 reacties
  • 30 oktober 2024
  • 16 maart 2025
Can I request something about the firmware?
Currently, it’s not possible to select text at all. ALso, auto-translation isn’t offered nethier in Chrome or Firefox. I guess the text is not “seen” by the browsers as well.
I really appreciate all the efforts, the webpage looks more responsive now, but it’s a total disaster I can’t even select text to copy it somewhere for translation. Please fix it, it really hurts.
BruisTablet
Topper
  • 1358 reacties
  • 16 maart 2025
The v12 box is behind with software. On v10 box all the mentioned issues are gone. They need to update.
